Home » Sponsored » Pi Speakers » old version of Pi4 pro
Re: old version of Pi4 pro [message #52646 is a reply to message #52644] Tue, 16 September 2008 12:15 Go to previous messageGo to previous message
Use the new crossover, as it has smoother response through the crossover region.
The two-way matched-directivity configuration trades simplicity and fewer crossover points for higher bandwidth required of the midwoofer. The three-way cornerhorn configuration reduces bandwidth, in turn reducing IMD, while retaining matched directivity but it is a more complex system with one more crossover point.
Both designs offer controlled directivity that results in smooth response on and off axis over a wide 90 x 40 pattern. The two-way has collapsing directivity up to 1kHz, becoming constant by 2kHz or so. The three-way begins to become directional down around 300Hz, just above the room's modal region.
Previous Topic: Pi 2 tweeter substitution?
Next Topic: seven pi corner horn
Current Time: Fri Nov 06 08:21:07 CST 2026
