Home » Sponsored » Pi Speakers » I will check the cables first...I will check the cables first...I will check the cables first...
Re: Don't ask? [message #52560 is a reply to message #52557] Sun, 31 August 2008 06:12 Go to previous messageGo to previous message
Hardly compelling; discovering a ground fault hum when first powering up Friday, I went after the known loose RCA females attached to the Faraday cage of my tonearm. 4 hours later, I can now field-strip an SME III in the dark but everything is OK except I can discern no way to tighten the crimp-on connectors to the cage.
Turning to the phono IC's, I discover no continuity for the right channel neutral in about 10 seconds and fix it in 10 minutes.
As others have reported, the Eichmann Bullet neutral pin is fragile and had broken right where it inserts into the plastic collar. I "glued" it back together with solder so expect it to fail again. No more Eichmanns for me.
Previous Topic: Woofer for Econowave
Next Topic: 2-Pi BASS ???
Current Time: Sat Oct 17 10:50:14 CDT 2026
