Home » Sponsored » Pi Speakers » 4pi port question
Re: 4pi port question [message #52536 is a reply to message #52535] Mon, 25 August 2008 22:29 Go to previous message
I found that cutting the port hole with a jigsaw slightly undersize, then carefully lining up and gluing on the port worked great. Eliminated the need for a router template to get the hole right.
After the veneer was applied, I then routed the hole using the port as a guide with a 1/4" flush trim bit. That left just a 1/4" round in the corners which looks good.
Be sure there's no dried glue on the interior surface of the port to spoil it's use as a guide.
Previous Topic: Wow! Does this ever show off the new crossover!
Next Topic: What a strange 24 hours! Come ramble with me.
Current Time: Sat Oct 17 05:16:24 CDT 2026
