Home » Sponsored » Pi Speakers » Need values for 4-pi x-over for 2226J (16 ohm)
Need values for 4-pi x-over for 2226J (16 ohm) [message #52471] Sat, 16 August 2008 10:15 Go to previous message
spkrman57
Wayne,
I can figure out the values for the LF circuit except for the zoebel cap value.
I know I will use 15 ohm resistor, but what value does the zoebel change to since the zoebel is run on the "light side" compared to normal?
I have most of the parts ready and will start building the crossovers after this weekend.
I will have the LF sections and HF sections of the crossover separate from each other since they will be connected to the appropriate impedance taps of my McIntosh 240 amp!
That way, there will be no loss of efficiency of the 16 ohm 2226 and the 8 ohm top end 902/650hz Edgarhorn.
Regards, Ron
Previous Topic: Open baffle subs?
Next Topic: Multible drivers
Current Time: Thu Nov 26 19:13:52 CST 2026
