Home » Sponsored » Pi Speakers » Open baffle subs?
Re: Not in my house! [message #52444 is a reply to message #52442] Tue, 12 August 2008 23:17 Go to previous messageGo to previous message
Yeah, that's too big. Hmm. I just don't think they'll work well on an open baffle. You could sure try it, but I don't think it's gonna make soup.
Is an in-wall infinite baffle an option? If you're renting, probably not. And I'm not sure it makes good sense for an experiment either. But I do think they would work well in an infinite baffle, essentially a huge box. Trouble with that is two-fold, one is you must cut a hole in a wall or ceiling and the other is you really need to model the room or do some measurements to know where to place them. It would suck to cut holes first and then find out where you placed 'em caused huge room modes.
Might be best to sell 'em and get subwoofers that work well in smaller boxes. If you could get a pair of small subs, you could place them strategically to blend with the bass of the four π's to smooth room modes. That's the ticket, 'cause it gives you a deep bass foundation and smooths room modes at the same time.
Previous Topic: stuffing midhorn back chamber?
Next Topic: Need values for 4-pi x-over for 2226J (16 ohm)
Current Time: Fri Oct 23 11:36:53 CDT 2026
