Home » Sponsored » Pi Speakers » seven Pi midhorn
Re: seven Pi midhorn [message #52424 is a reply to message #52423] Thu, 07 August 2008 17:07 Go to previous message
Adrian Mack did a horn like that and its response looked pretty good. I chose a square throat because I could match the flare pieces nicely. But either way, there are path length differences that chew up some of the upper frequencies.
My thinking was if I used a square thoat, the flare transition would be pure. The path length differences are within the compression chamber, but without a phase plug, there are path length differences using any throat shape. The compression chamber forms a low-pass filter, and the path length issues add to that. It becomes a variable, where cone and dust cover size and shape affect the response. This set of variables is hard to model without FEA, so you pretty much have to build and test. Every model of driver will be different.
Previous Topic: Is it possible to derive Le?
Next Topic: Anybody try these B&C aluminums?
Current Time: Tue Oct 20 20:57:12 CDT 2026
