Home » Sponsored » Pi Speakers » 18 Pi crossover
Re: 18 Pi crossover [message #52326 is a reply to message #52325] Tue, 15 July 2008 11:34 Go to previous message
No, I haven't gone through the seven π design yet with the same level of detail I did with the four π. However, I did look at it with the system briefly and it looks good enough that I'm not sure any optimations will be there to find. It is pretty well optimized already.
I am going through each of my designs with the Smith & Larson system, importing the Spice model and making measurements to see if any optimizations are possible. The four π was first, and I'm getting ready to double-check the three π. I expect the same crossover from the four π should be what is best for the three π because the HF horn/drivers used are the same and the baffle spacing is approximately the same. But it can't hurt to check, and it's the next one up. Then I'll do the six and seven π models. As I said, I don't expect to find much movement there.
Previous Topic: 4 pi crossover ???
Next Topic: 4Pi horn
Current Time: Sat Oct 17 07:27:25 CDT 2026
