Home » Sponsored » Pi Speakers » Matching directivity in the vertical and the horizontal planes
Re: Baffle spacing, null angles, etc... [message #52306 is a reply to message #52305] Thu, 10 July 2008 13:31 Go to previous messageGo to previous message
Shifting to a lower-order crossover on the woofer will shift the null angles up, yes. You could also move the crossover point a little bit or even just reduce the size of inductor L3 slightly if you just wanted a small change. Anything that reduces the phase shift of the woofer crossover will shift the null angles up; Increasing the phase shift will move the null angles down.
Previous Topic: one- Pi tunning freq.
Next Topic: Is it possible to derive Le?
Current Time: Wed Oct 21 00:20:55 CDT 2026
