Home » Sponsored » Pi Speakers » Crossover update and a monster recording
Active crossover settings [message #52258 is a reply to message #52257] Sun, 29 June 2008 19:35 Go to previous messageGo to previous message
Sounds good, Bill, keep us posted.
I know how the passive crossover sounds, and I think you'll be impressed when you're done with it. But active crossovers have definite advantages too. The trick is dialing it in. The passive has already been optimized with Spice and WTPro. So if you implement an exact copy of it in an active crossover, the sound will be smooooooth.
While you're trying different setups, try these settings: 3rd order Butterworth 1.3kHz low-pass for the woofer, 3rd order Butterworth 1.6kHz high-pass for the tweeter with 6dB/octave augmentation starting at 4kHz. Those settings should make your active crossover give very close to the same signals as the passive crossover does. You'll have the passive crossover's excellent on-axis and off-axis response, with the added benefits of reduced bandwidth on each amp from going active.
Previous Topic: 8 Pi x-over ?
Next Topic: Headphones with smooth freq.
Current Time: Fri Nov 06 00:37:50 CST 2026
