Home » Sponsored » Pi Speakers » 7 Pi bass cabinet
Re: More woofers - helps to smooth room modes [message #52214 is a reply to message #52213] Thu, 12 June 2008 20:22 Go to previous messageGo to previous message
Yes, if your amp can handle a 3Ω load, you can use a series coil and wire across your existing speakers. But it would be better to use a plate amp mounted on the subwoofer box. They don't cost much and will allow you to set the volume level of the subs to help blend them better. Something like one of these will do nicely:
Previous Topic: Wayne, can I have the plans for the seven pi 18?
Next Topic: 4 pi x-over with Kappa pro 15lfa
Current Time: Mon Nov 16 04:36:03 CST 2026
