Home » Sponsored » Pi Speakers » 2Pi towers anyone tried a T amp? Trends TA 10.1 or Pop Pulse T 40i or?
Solid state amps [message #52091 is a reply to message #52089] Mon, 28 April 2008 11:34 Go to previous messageGo to previous message
I have owned several solid-state amps over the years, from chip amps to larger discrete amps. Everything from 10 watt chips to 100 watt chips to 1200 watts developed using banks of parallel NPN and PNP transistors. I've never owned a T-Amp but have heard several. They sound fine until pushed hard. I guess that could be said of any amplifier.
As long as an audio amplifier is used well under its limits, it sounds good to me. Except for cheap little amps that have excessive zero-crossing distortion, I find this to be true of most amplifiers. Where they start to get weird is when they are pushed hard. Most amps sound bad when they get close to clipping but some are milder than others and some are downright harsh.
I have been particularly fond of the late seventies Yamaha amps using integrated circuit outputs. I also like NAD amps. For all out power, Crown makes great gear. On the smaller end, the National 3875 is a good chip amp. Be sure the power supply provides enough current for full output without a lot of voltage drop and use a lot of capacitance to keep load ripple down to a minimum.
Previous Topic: low mid tapped horn
Next Topic: pi6 crossover
Current Time: Fri Oct 23 13:18:04 CDT 2026
