Home » Sponsored » Pi Speakers » Pi-alignment for JBL 2240 18" driver
Pi-alignment for JBL 2240 18" driver [message #51932] Sun, 23 March 2008 19:11 Go to previous message
spkrman57
Hi Wayne!
Been too long since I talked to you last!
Could you run a quick cabinet size and tuning for me please???
I'm looking at running a pair of JBL 2240H's up to 800hz for use as 2-way(larger 1.5" or 2" compression driver on Edgarhorn).
I expect the bottom end to drop off around 60hz if my Winisd calculations are close.
I'm thinking using 3 cubic ft bot tuned to 60hz.
What's your thoughts on this, and would a single coil (on the 2240H) work at 800hz like the 2205 does? If it does, what value do you recommend(maybe 1.5 mH)???
T/S of JBL 2240H (8 ohm)
Qts - .23
Qms - 2.2
Qes - .25
Vas - 17 cubic ft
Fs - 30 hz
Le - 1.4 mH
Thanks in advance!
Regards, Ron
Previous Topic: 2 Pi's - Inducters for the Alpha 10's
Next Topic: Just one more music link...
Current Time: Sun Nov 22 23:26:34 CST 2026
