Home » Sponsored » Pi Speakers » Where are enclosure plans?
Re: Where are enclosure plans? [message #51784 is a reply to message #51783] Wed, 30 January 2008 08:19 Go to previous message
Send me your E-Mail address and I'll send you the plans.
All models of π speakers are either bass-reflex or horn, or a combination of the two.
If a ducted vent is used, then port material is included. For example, the two π kit uses a 2" duct so a tube is included. The two π tower does not use a duct, rather, the port is just a hole cut in the rear panel. The four π speaker uses a rectangular port made from wood.
Kits include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, tweeter compensation cable assembly, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
Previous Topic: SEP compatibility
Next Topic: Sub for Heresy's
Current Time: Mon Nov 02 06:24:52 CST 2026
