Home » Sponsored » Pi Speakers » Placement
Pro 4 [message #51644 is a reply to message #51643] Fri, 21 December 2007 01:13 Go to previous messageGo to previous message
Zene Gillette is currently offline  Zene Gillette
Wayne ... thx for Pro 4 plans. If I use as separate woofer boxes I need to compensate for horns. Can I have the exact net volume you use? That way I can add my bracing to get internal volume dead on. I tend to get a little crazy on strength. I don't think the box Q change will effect porting, but not sure. Should I use an adjustable port?
Speaker displacement also, if you have?
Zene
Previous Topic: Comments on this elementary crossover essay?
Next Topic: Tweakin' agin
Current Time: Wed Nov 04 04:07:48 CST 2026
