Home » Sponsored » Pi Speakers » Placement
Re: You've got mail! [message #51641 is a reply to message #51640] Wed, 19 December 2007 20:19 Go to previous messageGo to previous message
In most home listening rooms, I would prefer seven π cornerhorns. If corners aren't available, then go with four π speakers instead. In either case, you can augment the bottom octave with dedicated three π or four π subwoofers, if desired.
Pro seven π cornerhorns are tuned to be slightly overdamped, which makes a good conjugate for corner loading. Pro four π speakers are too, for that matter. They work well in small to medium sized rooms, and don't become boomy when placed near boundaries. They are designed to work best with boundary reinforcement. You'll get good response to 40Hz with a 2226 in these designs, even without a sub. And they aren't terribly large, so they don't "take over" the room.
Very large rooms have different requirements than small to medium size rooms. You won't pressurize the room and get "cabin gain" in a large room or outdoor space, so tuning is a bit different. And you expect to push the speakers much harder, so you want to optimize performance at high drive levels. For example, it is easy to generate over 100dB in a medium size room with very little distortion from a good quality direct radiating woofer. One hundred feet away from the stage at an outdoor concert is a little different. That's where the advantages of a large push-pull basshorn become apparent.
Previous Topic: Comments on this elementary crossover essay?
Next Topic: Tweakin' agin
Current Time: Sun Oct 04 11:44:29 CDT 2026
