Home » Sponsored » Pi Speakers » Placement
Re: You've got mail! [message #51640 is a reply to message #51639] Wed, 19 December 2007 17:03 Go to previous messageGo to previous message
Zene Gillette is currently offline  Zene Gillette
Wayne ... Then can I ASSume that by not using the 12PI my original idea to use Pro 7's is the best way for reasonable deep bass with authority? If I must relinquish corners for side wall placement, will I loose much in low frequency and quality? Would you be kind enough to explain different placements for them? A 70hz cutoff gives me almost 8' distance to UB to play with. Thinking of two side by side against rear wall. Only have 6' width there between doors, but would be within 3' of corners.
Zene
Previous Topic: Comments on this elementary crossover essay?
Next Topic: Tweakin' agin
Current Time: Tue Oct 06 05:02:01 CDT 2026
