Home » Sponsored » Pi Speakers » Placement
You've got mail! [message #51639 is a reply to message #51638] Wed, 19 December 2007 15:56 Go to previous messageGo to previous message
I'll send plans for the v1 model, which is the same size as the v2 model. Remind me around the first of the month and I'll send you the v2 plans. It's a little bit simpler build and has smoother response than v1, more like the original model and the prototype than the first production model was.
Most everything is the same except the motor chamber layout. The new version is a little easier to build because it doesn't need the fill, and the chamber sizes are nearly ideal. But other than that, they are very similar horns.
Be aware that the 12π hornsub is very large and powerful. It is overkill for all but the largest rooms, theaters and outdoor use. I designed it to provide very high fidelity at high power levels, the kind of thing needed for outdoor concerts and the like. So it is probably a lot bigger than you need.
Previous Topic: Comments on this elementary crossover essay?
Next Topic: Tweakin' agin
Current Time: Wed Nov 04 03:01:18 CST 2026
