Home » Sponsored » Pi Speakers » Theater 4 and 7 plans
You've got mail! [message #51597 is a reply to message #51593] Mon, 10 December 2007 10:44 Go to previous messageGo to previous message
I'd prefer the cornerhorns, and while the Theater sevens sound nice, they may be a bit big for you. If so, you might consider the Theater six π instead. It's a great sounding speaker. I'll send plans for the Theater Series three π and six π in addition to the four and seven, just in case.
The seven π cornerhorns present a very flat impedance curve, so I expect your amplifier will have no trouble driving them. The Theater three π is an excellent speaker, but impedance peaks in the bass range are a little higher.
I prefer to place cornerhorns at opposite ends of a short wall in rectangular rooms. I prefer this on rooms with 5/7 ratio or so. You're is a little bit more narrow than that, but this only makes it even more important that you place them on the short wall. What this does, is makes the best listening area in the first 3m back from the wall where both speakers are.
Previous Topic: Specs
Next Topic: Pi mid horn vs. Klipsch Lascala
Current Time: Thu Nov 05 06:09:29 CST 2026
