Home » Sponsored » Pi Speakers » matching a Table Tuba bass horn
seven π cornerhorn [message #51578 is a reply to message #51577] Mon, 03 December 2007 09:01 Go to previous message
You might be able to use it as a bass bin for a seven π cornerhorn. I'm not sure how it sounds above 100Hz though, so it may not work. It needs to be smooth up to around 300Hz for good integration. You'll also need a delay line because of path length. One of the advantages of the seven π bass bin is it keeps the woofer and midrange within 1/4λ so integration is seamless. You just can't tell where the bass bin leaves off and the midhorn takes over. You might lose that if you swap out the bass bin with something else.
Previous Topic: Pro 7
Next Topic: new sounds!
Current Time: Thu Nov 19 07:27:31 CST 2026
