Home » Sponsored » Pi Speakers » Pro 7
Re: Pro 7 [message #51570 is a reply to message #51568] Thu, 29 November 2007 14:19 Go to previous messageGo to previous message
The midhorns are avilable as a flat pack kit, or you can build them yourself from the plans. The wooden tweeter horn is available separately, or you can use an Eminence H290.
As for the seven π bass bin, it is slightly overdamped which works well for corner loading. You'll definitely get some room gain, so you don't want to overdo it by having an alignment like B4. With the 2226 in a seven π bass bin, you can expect nice clean bass down to 40Hz, with gradual rolloff below that.
Previous Topic: Imaging with Pi Speakers
Next Topic: matching a Table Tuba bass horn
Current Time: Thu Nov 19 07:21:06 CST 2026
