Home » Sponsored » Pi Speakers » Pro 7
Pro 7 [message #51568] Wed, 28 November 2007 05:53 Go to previous message
Zene Gillette is currently offline  Zene Gillette
Wayne ... I am using P.audio P150 (JBL 2226 clone) in backloaded JBL Model 34 bass horns. They couldn't produce bass with a stiff wind. I would like to use the Model 34's for UB and the P150's in your Pro 7's. Assuming they will perform close to the JBL's, what is the bass extension I might get from them? Your Boxplot doesn't take into consideration corner placement if I read right. They will be driven by two 375 watt plate amps (OAudio) that has built in EQ so I can tweak if necessary.
Plan is to use them for subwoofers only up to 60hz-80hz. If good idea will you send plans. I will certainly accept alternative ideas. Just for reference what will stacked Pro 7's do?
The JBL Model 34 horns originally used JBL D130's. Can you recommend a driver that might work well considering they only need to go to 50hz or so?
Can I get your mid and tweeter horns separate?
Thanks, Zene
Previous Topic: Imaging with Pi Speakers
Next Topic: matching a Table Tuba bass horn
Current Time: Thu Nov 19 07:21:02 CST 2026
