Home » Sponsored » Pi Speakers » Theater Seven Pi Question.
Re: Theater Seven Pi Question. [message #51514 is a reply to message #51512] Sun, 28 October 2007 20:13 Go to previous messageGo to previous message
You don't want to do that. The midhorn needs to sit squarely on top of the bass bin for several important reasons. The midhorn and bass bin need to be within 1/4λ of each other for proper summing. The crossover depends on that. That's the main thing, really, and is a deal breaker for remote positioning. The midhorn doesn't go low enough to be placed remotely, because you would need a lower crossover point, like what you might do with a subwoofer.
There are also other reasons for wanting the midhorns in the corners on top of the bass bins. One is that the corner helps smooth midhorn response. It is physically large, but it is acoustically small at the lowest frequencies. Corner loading helps make it act like a larger horn and smooths its response. Also, the π cornerhorn design uses sound sources that radiate 90°, matching the expansion of the room corner. Each sound source is toed in 45° with a pattern that covers 45° on either side. This creates a uniform reverberent field. When moving the midhorn and tweeter away from the corner, you lose these benefits.
Previous Topic: positioning pi 2 towers
Next Topic: Studio Two Pi
Current Time: Mon Nov 02 07:38:26 CST 2026
