Home » Sponsored » Pi Speakers » Theater Sevens too small large for our place..dang.
Re: Sevens on their side [message #51371 is a reply to message #51370] Sun, 26 August 2007 09:04 Go to previous messageGo to previous message
dB is currently offline  dB
(It) Is going to be a new design.
Check Wayne notes about vertical alignment. I guess it is possible unless someone says otherwise because of xover frequency or something else. You probably will lose a little bass. I am not sure of Wayne's approval, afterall it's a PiSpeaker. (You) Should check max. distance between speaker drivers also. I am not sure about the phase on the low frequency xover/speakers if it is ok or not since they (mid/tweet) will be advanced/forward. Overall I guess you have some work to do.
Previous Topic: Near field monitors...
Next Topic: I just completed my Theater Four..
Current Time: Wed Nov 18 01:34:30 CST 2026
