Home » Sponsored » Pi Speakers » Pi Sevens up and running!
Re: Hardwood floor [message #51333 is a reply to message #51332] Thu, 09 August 2007 18:09 Go to previous messageGo to previous message
Tim Barnes is currently offline  Tim Barnes
My floor may be marginally better than some - it's an engineered hardwood floor (basically plywood planks) laid on a few mm of foam, over a particle board floor on joists (I used to have carpet). I also have a big rug in the middle of the room and quite a lot of soft furniture.
But in any case, I'll see what it sounds like under the floor. I imagine that if I use Cara to work out room modes, and then when I measure I find something different, it may be because of the sub-floor space?
I have some other things to do as well - explore moving the piano to another part of the room to let the horns do their thing with fewer obstructions; put some kind of absorbent pad under the piano (a Jon Risch-style trap lying on the floor?); and then we'll see where I am.
The room needs to get back to the clean and minimalist look it had before I put all the stuff in there - it is meant to be a peaceful place, not just a listening room...
Previous Topic: JBL 2416
Next Topic: what design can i throw 8 jbl 2206J's in?
Current Time: Thu Oct 29 00:29:15 CDT 2026
