Home » Sponsored » Pi Speakers » Pi Sevens up and running!
Re: Pi Sevens up and running! [message #51329 is a reply to message #51327] Wed, 08 August 2007 12:26 Go to previous messageGo to previous message
I would suggest running braces along the front. Glue 1x2 wood along the panel with the taller dimension (2") standing up. That way it will resist panel flex.
If you find room modes are troublesome, you may want to add a couple subwoofers. This may seem counterintuitive, especially if you feel that the bass is strong. But what will happen is bass will be made more smooth as a result. Use CARA and figure out where to place the subs. I have found many cases where the four opposing corners are best, and others where they're not. Of course, your decor will determine what you have to work with too.
I usually suggest the additional woofers be the same as the ones in your sevens. They don't have to be cornerhorns, but they surely can be. If not cornerhorns (with mids and tweeters), then low-pass them very low, below 100Hz. This prevents localization and improves integration, by keeping sound sources acoustically close. Or you can go with a different approach, using woofers like the LAB12 that are tuned for a very deep range. This lets you hit even deeper bass notes while providing smoothing of the overlapping range. You may be able to install subs in cabinets that fit under existing furniture. You can usually find a configuration that models well in CARA and that also fits in nicely with your room decor.
Previous Topic: JBL 2416
Next Topic: what design can i throw 8 jbl 2206J's in?
Current Time: Thu Oct 29 00:32:31 CDT 2026
