Home » Sponsored » Pi Speakers » De-ringing my Pi Seven cabinets
Re: Midhorn bracing [message #51256 is a reply to message #51255] Tue, 10 July 2007 10:53 Go to previous messageGo to previous message
Loosely pack the sides, top and bottom surrounding the flare with insulation:
http://www.pispeakers.com/misc/Rubber_Ball_Brace.jpg
Midhorn packed with insulation and rubber ball brace in place
The picture above doesn't show the gasket, but one is used to seal the access panel. A suitable material for this purpose is PVC sheet rubber, commonly used for shower pans. You can get it at most builder's supply houses and cut it to fit. Makes excellent gasket material.
http://www.pispeakers.com/Basshorn/Cutting_Gasket.jpg
PVC sheet rubber, cut to form a 12π side panel gasket
Previous Topic: 12pi Basshorn , assembled
Next Topic: Two Pi towers with HiVi RT2C-A Planar transducers...?
Current Time: Fri Nov 13 09:07:17 CST 2026
