Home » Sponsored » Pi Speakers » De-ringing my Pi Seven cabinets
Re: Midhorn bracing [message #51255 is a reply to message #51254] Mon, 09 July 2007 23:37 Go to previous messageGo to previous message
Tim Barnes is currently offline  Tim Barnes
Thanks, Wayne. I have put in the braces on all four sides...I haven't stuffed it with fiberglass yet though, and I haven't mounted the back panels. I'll do as you suggest. It looks from your picture as though you stuff the angled areas around the horn pretty thoroughly?
Also, do you use some kind of strip to seal the back panel to make the entire cabinet airtight? I couldn't see anything on the picture with the ball braces.
tim
Previous Topic: 12pi Basshorn , assembled
Next Topic: Two Pi towers with HiVi RT2C-A Planar transducers...?
Current Time: Fri Nov 13 09:06:08 CST 2026
