Home » Sponsored » Pi Speakers » Damping material
Two π tower - braces and damping material [message #51241 is a reply to message #51237] Thu, 05 July 2007 21:52 Go to previous messageGo to previous message
Use R11 or R13 lining the line the top, one side and the front up to the woofer. You'll also want two pieces of insulation to span the cross-section. These are conveniently placed, resting on cross-braces inside the cabinet. This breaks the cabinet into three partitions, and midrange energy cannot pass through, only bass. The cross-section insulation impedes standing waves from setting up inside the cabinet.
Bracing is important in that it keeps panel vibrations to a minimum. It is important that the cabinet not add sound of its own, and you should be able to strike the cabinet with your knuckles and not hear a resonant "drum head" sound. As mentioned above, the braces also serve to hold cross-section dampers, one a third of the way up and another a third of the way down. They should be cross braces or window braces and they should double as a place to hang partitioning pieces of insulation across the cross-section of the cabinet.
Previous Topic: Two Pi Towers with H290/PSD2002 - do-able?
Next Topic: 12pi Basshorn , assembled
Current Time: Fri Nov 20 01:10:28 CST 2026
