Home » Sponsored » Pi Speakers » Suitable top for basshorn
Delay lines [message #51210 is a reply to message #51209] Tue, 26 June 2007 16:17 Go to previous message
Sure, passive line level crossovers could be used. If you think about it, analog active filters are generally just passive components surrounded by active buffer stages. So a passive line level crossover is not much different than an analog active crossover.
On the other hand, the basshorn is long enough that some delay for the mains is in order. The midrage and tweeter horns are about the same length, but the midbass horn is longer. Appropriate delays for each subsystem could be done with position, but electronic delay lines are probably more convenient. This makes more sophisticated crossovers somewhat attractive.
Previous Topic: altec valencia n-800-F crossover
Next Topic: 7 PI CORNER HORNS
Current Time: Thu Oct 29 11:05:15 CDT 2026
