Home » Sponsored » Pi Speakers » 16ohm driver for 7Pi
Re: 16ohm driver for 7Pi [message #51189 is a reply to message #51184] Tue, 19 June 2007 22:45 Go to previous message
Kim Schultz is currently offline  Kim Schultz
Thx Wayne, as always you´re very helpful.
I did some measurements yesterday with and without a 15ohm resistor in parallel, and the only thing that seemed to change was the overall level .
The response looked very much the same, with a little flatter top end response when using the 15ohm parallel resistor.
I looked through your links to previous posts, and found the one where you suggest changing the l-pad and compensation circuit only. This is great news, and would make a cheaper and easier implementation of the drivers possible.
Also I will play around with Spice a do some simulations to confirm what I see and hear.
The Altec 902 driver sounds smoother and more natural than the PSD-2002, I will post measurement when I get them done.
Regards
Kim
Previous Topic: What's Going On
Next Topic: Plans for Premium Four
Current Time: Tue Nov 03 03:50:23 CST 2026
