Home » Sponsored » Pi Speakers » anyone tried B&C compression drivers?
Re: anyone tried B&C compression drivers? [message #51150 is a reply to message #51149] Tue, 29 May 2007 16:31 Go to previous messageGo to previous message
dB is currently offline  dB
The B&C is 7.8Ohm / Eminence is 6.x Ohm. It gives more 0.5dB in aimspice. If there is a problem in the sound output (with it being to high) a 1.0 Ohm resistor in series (1+5.5 Ohm) would be fine (if there is the need). I am not sure the R1 resistor is 5.5 Ohm.
Previous Topic: 2Pi tower upgrade
Next Topic: High Efficiency 15" Woofer Suggestions For 9 Cu Ft Ported Box ??
Current Time: Fri Oct 23 09:46:47 CDT 2026
