Home » Sponsored » Pi Speakers » Theater 4 crossover upgrades
Re: Same values, or different? [message #51127 is a reply to message #51126] Mon, 21 May 2007 12:11 Go to previous messageGo to previous message
Skip_Pack is currently offline  Skip_Pack
Same Values, usually the voltage ratings will be higher than you
need for crossovers, but that's not a problem.
Motor run caps are (at least the new ones) metalized polypropylene,
just like the less expensive conventional polypro caps, but I believe
they are oil filled. In any case, they are very smooth, and available
in large values (10-40 uf) for not too much money. If you want
startling detail and smooth, Obligato might be the only somewhat
more expensive route before you succumb to VCaps, Mundorf, . . .
They are big, but that's no big deal in a speaker. I glue in a little
shelf and then use a tie-wrap anchor and tie-wrap. I wouldn't let them
dangle.
Skip
Previous Topic: Looking forward to a report from LSAF...
Next Topic: Xover Summing Question
Current Time: Tue Oct 20 19:10:27 CDT 2026
