Home » Sponsored » Pi Speakers » Midrange Horn Measurement problems
Re: With top and bottom transitions [message #51086 is a reply to message #51085] Sun, 13 May 2007 09:30 Go to previous messageGo to previous message
Your horn is starting to look pretty good. That is similar response to my midhorn. If placed in a corner, the walls act like horn extensions. The horn isn't designed to be used outside, but if it were, it would need to be longer and the mouth transition would benefit from a wider exit angle, As it is, indoors, the walls do this for us.
Previous Topic: Wayne, question about One and Two Pi XO
Next Topic: h290 bolt size
Current Time: Thu Nov 19 06:30:56 CST 2026
