Home » Sponsored » Pi Speakers » Hacking the One Pi- suggestions?
Give it time, then tweak [message #51040 is a reply to message #51035] Thu, 03 May 2007 01:36 Go to previous message
Kim Schultz is currently offline  Kim Schultz
First off I´m a true believer in break-in of both speakers and amps.
1. If the high end is your problem, it has to do with the tweeter, and that will need some break-in before that sounds its best.
2. The bass drivers need some exercise to loosen up their suspension, then you should gain a bit more low end extension.
3. How did you dampen and brace the speakers, maybe try to remove a bit of damping to see if that clears up the midrange.
I have build many gainclones, and they all sound great, but again they need some break-in.
Do you know the value of the input capacitor on the amp, is it 47uF ?
If it is you should be alright.
My suggestion is this:
wire one speaker in reverse phase, and put them pretty close together, face to face, cover them with a blanket to minimize the sound comming from them.
Then play pink noise or just some rock music through them for a day or so, then they should start opening up.
You should play it pretty loud so you can see the bassdriver moving, but not bottoming out.
Previous Topic: my first DIY speaker
Next Topic: Pro 4 + seven midhorn and tweeter
Current Time: Fri Nov 13 07:15:24 CST 2026
