Home » Sponsored » Pi Speakers » Pro 4 + seven midhorn and tweeter
Re: Pro 4 + seven midhorn and tweeter [message #51032 is a reply to message #51030] Tue, 01 May 2007 09:03 Go to previous messageGo to previous message
beto1 is currently offline  beto1
Hi dB,
thanks for the link. Very impressive products. Here we have also phenolic plywoods used for concrete work (now I'm use it) , but I'm affraid that ours are made with pine. The point is , as far as I know, veneers fibers homogenity to avoid unwanted voids.
I will check tomorrow at work, how good can be our phenolic boards for speakers matters.
Having also MDF here, of course, it will be a nonsense import baltic birch or othe fine board, by the way. Maybe we can add some sealing product before apply the venners to increase moisture protection. Also, we can use some poliurethane treatment over the venners to add the wanted finish and protection.
Best for you.
p.s. wich Pi speakers do you have or proyect it?
Previous Topic: Hacking the One Pi- suggestions?
Next Topic: One Pis done
Current Time: Thu Nov 26 06:57:12 CST 2026
