Home » Sponsored » Pi Speakers » Pro 4 + seven midhorn and tweeter
Re: Pro 4 + seven midhorn and tweeter [message #51010 is a reply to message #51007] Mon, 23 April 2007 19:59 Go to previous messageGo to previous message
Ply is lighter and stronger than MDF. With very large and heavy drivers MDF does not hold up well. I just find ply to be the better material. For you, MDF is probably the better choice.
I have a plywood cutting jig I made that works well. Click the attached link. You will have to click on each image icon to view the photos if you are not registered at that site.
I use aliphatic wood glue with bats and screws, screwed from the inside so they don't show. I cover the ply edges with "birch tape". Then sand, stain, and apply several coats of hand rubbed tung oil.
Previous Topic: Hacking the One Pi- suggestions?
Next Topic: One Pis done
Current Time: Thu Nov 26 06:57:05 CST 2026
