Home » Sponsored » Pi Speakers » New 10π basshorn subwoofer - Check it out
Re: New 10π basshorn subwoofer - Check it out [message #50986 is a reply to message #50985] Sun, 22 April 2007 10:33 Go to previous messageGo to previous message
Only the 12π basshorn sub uses push-pull drive at this time. The 10π will also.
When I considered push-pull for seven π cornerhorns, I realized that the top of the line model already has a mechanism for reducing distortion caused by flux modulation, so push-pull drive wouldn't be as effective for it. The woofer used in the Professional Series seven π uses a shorting ring that is effective down to below 100Hz. Shorting rings begin to lose effectiveness at subwoofer frequencies, so I'm not sure they make sense for dedicated subwoofers but for the bass bin of a cornerhorn, flux-stabilized woofers are perfect.
Previous Topic: theatre 6 plans please..
Next Topic: Delta 12LF crossover in Theater 6
Current Time: Thu Nov 05 05:29:45 CST 2026
