Home » Sponsored » Pi Speakers » Fitting corner horns into a multi-use room
Re: Fitting corner horns into a multi-use room [message #50958 is a reply to message #50957] Sat, 14 April 2007 10:27 Go to previous messageGo to previous message
Tim Barnes is currently offline  Tim Barnes
Thanks for the quick reply. I don't think the piano has been a problem so far - and in any case I don't think there's much I can do about it as we like having the piano in there and don't have another room that would be suitable. Currently my speakers are right in front of the piano and I'm not aware of any adverse effects (perhaps I just have cloth ears).
With the more uniform sound field should I expect more or less "imaging" than I would have with a more traditional out-in-the-room arrangement?
Next question: It seems that all the 7 Pi speakers are identical except for the woofer - is this right? If so, are the sound quality differences between them relatively smaller than between the two-ways where the woofer is crossed over higher? I'm trying to think through the economic tradeoff... I like to listen at moderate levels with headroom for the climaxes, but I'm not often looking for the levels of SPL your systems seem capable of.
Finally, could you send me a copy of the 7 pi plans, please?
I appreciate your help,
tim
Previous Topic: reccomended amplification power
Next Topic: Theater 4 crossover
Current Time: Thu Nov 05 15:01:41 CST 2026
