Home » Sponsored » Pi Speakers » theater six?
Re: theater six? [message #50857 is a reply to message #50856] Tue, 20 March 2007 20:32 Go to previous message
You could probably do something like that, sure. It would probably sound pretty good. The midhorn I designed probably wouldn't work well with the Alpha 8MR, but you could change the throat and flare a little bit and come up with a very similar design. If you were able to get response up to 3.5kHz, you could probably crossover to something like the APT series tweeters on top. On the lower end, I expect you could get response down to 400Hz from an Alpha 8MR midhorn.
Personally, I like to crossover a little bit lower than that. Lots of three-way loudspeakers have crossover between 400Hz and 600Hz. It's kind of a popular place to put a crossover point, I suspect probably because it's easier to get a smaller midrange to work there. But that is right in the middle of the vocal range and I don't like to crossover between 200Hz and 2kHz if I can help it. I generally try to design my speakers so that as much as possible of the 200Hz-2kHz band is covered by one driver.
Having lower crossover allows the vocal range to be covered by one driver. Woofer-to-mid distances can be greater and summing is still good. Midbass room modes can be smoothed by having sound from both the midhorn and the bass bin. So having a lower crossover point for the midrange seems ideal to me.
Previous Topic: Pi 3-way crossover
Next Topic: 4 Pi's with midhorn
Current Time: Thu Nov 12 00:37:17 CST 2026
