Home » Sponsored » Pi Speakers » Pi 4 Stage Series plans, and a few questions?
Re: Pi 4 Stage Series plans, and a few questions? [message #50809 is a reply to message #50791] Sun, 11 March 2007 20:09 Go to previous messageGo to previous message
dB is currently offline  dB
I would see under the names of DIY (speakers) and Enclosure Assembly.
If you use screws with glue is better but you will be much more tired from that. The white glue (carpenters glue) is the best one. It all depends if you use wood, particle board or plywood, MDF and also about it's thickness. MDF (and veneer) is very well accepted. YOU ALSO NEED GOOD LONG CLAMPS TO LET THE WOOD/GLUE DRY.
"...you can never have too many clamps."
CHECK ALSO WEBSITES LIKE THIS
http://happycarpenter.blogs.com/the_happy_carpenter/carpentry/index.html
Previous Topic: Baffle step compensation
Next Topic: R13??
Current Time: Mon Nov 23 08:23:34 CST 2026
