Home » Sponsored » Pi Speakers » TAD 2 way.. need crossover.
Re: TAD 2 way.. need crossover. [message #50780 is a reply to message #50779] Wed, 07 March 2007 13:07 Go to previous messageGo to previous message
The critical components are those in series with the drivers. I'd consider the shunt inductor in the tweeter circuit fairly critical too. The Zobel isn't critical, although I would try a pseudo-first-order filter on the woofer, since you're near mechanical rolloff. That will make the total crossover slope higher than just the electrical filter slope. You don't need a Zobel with pseudo-first-order crossovers, it's just a single series coil.
Previous Topic: dedicated sub
Next Topic: Pi 2 Towers
Current Time: Wed Nov 04 21:24:09 CST 2026
