Home » Sponsored » Pi Speakers » RatShack 40-1034 Sub
RatShack 40-1034 Sub [message #50751] Thu, 01 March 2007 04:47 Go to previous message
I have a pair of RS 40-1034 drivers that I was planning to use for a subwoofer, but when I model the cabinet in WinISD it comes up with a massive sealed box (basically 3ft x 4ft x 6.75ft)if I want a fairly flat response. To get the box to a "reasonable" size (approx. 1ft x 2ft x 3ft) there is a huge bump starting at about 100Hz, hitting 2 db at about 45Hz, then dropping off to 0db at about 31Hz and -3db at about 27Hz.
Is there anything I can do in the crossover/filter that would help flatten the response? My worry is that if a have the filter roll off sooner to compensate then the drop on the back side of the curve will be pretty severe and I'll loose the bottom end. Alternatively, I thought about crossing them over at about 60Hz. But that seems a bit of a waste.
I couldn't find actually T-S parameters for these, but one source suggested that they are essensially 40-1026A's whcih have T-S parameters of:
Nominal Impedance:..........................8 ohms
Frequency Response:........................30 Hz - 3000 Hz
Free Air Resonance (Fs) Frequency:.........25 Hz
Infinite Baffle Resonance Frequency:..................................23 Hz
Piston Area (SD):..........................0.0523 m2
Rated Power Input - Nominal:...........................................50 W
RMS Thermal Power Limit (PMAX):.......................................100 W
Flux Density (BL):.............................6.66 TM
DC Voice Coil Resistance (RE, ohms):...........5.6 ohms
Voice Coil Inductance (LVC at 1 kHz):...........................................0.45 mH
SPL:...........................................88 +/- 2 dB/1W/1m
Moving Mass (Mms):.............................61.5 g
Electrical Q Factor (QES):..........................................1.13
Mechanical Q Factor (QMS):..........................................3.13
Total Q Factor:.................................0.83
Equivalent Acoustic Volume (VAS):..........................................297.19 I
Mechanical Suspension Compliance (CMS, UM/N):...766 UM/N
Mechanical Mass of Cone Assembly and Free Air Load:.................61.46 g
Mechanical Mass of Cone Assembly Only:..............................................54.59 g
Peak-to-Peak (maximum) Linear Excursion:........................................2.90 mm
Cutout:..........................................10 1/4 Inches/28.5 cm
Depth:...........................................5 1/4 Inches/14.3 cm
Power Handling:..................................50 Watts RMS
Magnet Weight:...................................17.7 oz
Speaker Weight:..................................72.9 oz
Any thoughts?
I was going to use these to supplement some computer monitors I wanted to build, but they now seem a pit overkill for that. So, maybe I'll use them with my Fostex horns.
Previous Topic: I think I found a substitute for the 2123 in 3-way
Next Topic: One Pi- Laurels and Nits
Current Time: Thu Nov 19 07:00:51 CST 2026
