Home » Sponsored » Pi Speakers » My first crossover network: pic and questions
Re: My first crossover network: pic and questions [message #50727 is a reply to message #50725] Thu, 22 February 2007 06:40 Go to previous messageGo to previous message
dB is currently offline  dB
The hot melt glue is not good when you have to change a component. Some factories use it with good results (acoustic).
(the xover) Looks good for me.(I just can't remember if those you use are non inductance resistors?, if they say so it's oki-doki). If like you say they are "to hot and melt the belts" will be a good warning sign, anyway they sell manufactured supports just for the resistors, try a good shop for that size you use.
The coils are just fine (perfect) I would put them apart because of the magnetic field, or then turn one 90 degrees.(Like one in the vertical pos. and one in the horizontal position).
Previous Topic: One last question
Next Topic: Pi 4 Professional
Current Time: Fri Nov 06 02:28:23 CST 2026
