Wayne Parham Messages: 19108 Registered: January 2001
I think I must have those plans still around somewhere but I'll have to look. Send me your E-Mail address and I'll reply with plans if I still have them.
You might also consider using something like the midbass horn designed for the 9 loudspeaker system. Its driver is a JBL 2226 and I think it will be a better horn than the old ten π was. It's an axi-symmetrical conical straight horn with flat walls, which makes it easy to build. You'll need a subwoofer with it though, because it is designed for use from 100Hz up is only good down to 80Hz or so. I don't have plans for it available yet, but it's a very easy horn in concept and in construction. It has a square throat, square mouth, and flat straight flare walls.
