Home » Sponsored » Pi Speakers » Hey, Wayne! You Rock!
Re: 12 Ohms and 1.8 Watts [message #50610 is a reply to message #50607] Sat, 27 January 2007 11:11 Go to previous messageGo to previous message
dB is currently offline  dB
bill thanks,
Speakers are different (as Wayne tell us all the time) from resistors. They change with frequency and resonance.
T/S Re for the JBL 2226J = 10.0 ohms
T/S Re for Eminence Delta10 = 5.42 ohms
“With just a coil; way too bright.” “I put back the attenuation from the 2123: 15ohm R parallel and 10hm R series. Tamed the Delta right in line.”
“ and for the woofer, I'd just use a 6.0mH coil in series and that's it.”
– bill
Is this your setup bill? Are you using only this 3 components for the two woofers/mid part? I'am just curious.
DB
Previous Topic: Wayne, can I have the plans for the 10pi?
Next Topic: 2 Pi tower making music!!!
Current Time: Sat Nov 28 21:41:17 CST 2026
