Home » Sponsored » Pi Speakers » Blow Fuse!
Re: Blow Fuse! [message #50585 is a reply to message #50572] Tue, 23 January 2007 10:36 Go to previous messageGo to previous message
Tuffer is currently offline  Tuffer
Thanks for all your help and advice guys. I am begining to think that perhaps I should consider bi-amping these boxes and only loaning them out with the associated amps/crossovers/limiters and my supervision. With the expense of all the crossover components, testing and possibilty of frying a few HF drivers I could have bought the other amp required. Should then be able to get the best out of the 15G40 driver also.
I will put this one down to just a bit of feedback or a dropped mic and replace the fuses in the meantime. It seems like tweeter protection and passive crossover construction in general is a bit of a mine field. Without lots of equipment ,time , patience and know how it's down to luck if it sounds right. Perhaps that is why so few of the pro audio suppliers get their passive boxes sounding good!
Previous Topic: Stage, Audiphile(?) or Professional?
Next Topic: First listen to the 3-way; I call them the......
Current Time: Wed Nov 04 17:36:44 CST 2026
