Home » Sponsored » Pi Speakers » Blow Fuse!
Crossover Slopes [message #50581 is a reply to message #50578] Mon, 22 January 2007 21:23 Go to previous messageGo to previous message
I always put a Zobel RC damper on any woofer that uses a passive crossover, second-order or higher. Sometimes, I'll run a midwoofer "wide open", or maybe with just a series coil. Of course, a woofer with a single series coil does not really have a first-order crossover since the load is not purely resistive. In fact, the woofer's voice coil is highly inductive, so a coil in series acts more like a voltage divider than a filter, making a sort of a shelved response. That's why I like to call them pseudo-first-order filters, to call attention to the fact that HF content is not attenuated with a 6dB/octave slope.
On the tweeter circuit, I load the crossover with a higher impedance to make it slightly underdamped. This combined with top-octave compensation provides a couple octaves of flat response before HF augmentation begins. It does this by providing a tiny bit of peaking down near the crosover frequency. The net effect is a response curve that looks like shown below, which both pads the tweeter down to match the midwoofer and also compensates for the high-frequency rolloff of the compression horn.
Previous Topic: Stage, Audiphile(?) or Professional?
Next Topic: First listen to the 3-way; I call them the......
Current Time: Wed Nov 04 15:40:33 CST 2026
