Home » Sponsored » Pi Speakers » Blow Fuse!
Re: Blow Fuse! [message #50573 is a reply to message #50571] Mon, 22 January 2007 16:35 Go to previous messageGo to previous message
dB is currently offline  dB
1. Place a RC damper for the woofer (between W+ and W-).
R= 7.6ohm (you can use 2 of those 15 ohm in parallel, or one 8 ohm, like the yellow ones you have)
C= 40uF (in series with R=7.6), you can use 33uF CAP and up close to 40/44uF (2x22uF in parallel).
2. Disconect (take out) the power resistor (15ohm) you have for the tweeter/to ground (between T+ and T-), (the 15 ohm one that is in parallel with cap / leave)
3. Use a lamp of at least 7/8 ohm, you can use two lamps in series to duplicate the effect of a resistor, if you use the lamp that Wayne said. Measure the lamp with Meter to have as many lamps to make 7/8 ohm.
The speaker at crossover point (-3dBs - 1600/1700 Hz) gives about 92dBs sharp, side of woofer and on the side of HF driver.
I think that's about it.
Best Regards
Previous Topic: Stage, Audiphile(?) or Professional?
Next Topic: First listen to the 3-way; I call them the......
Current Time: Wed Nov 04 15:40:20 CST 2026
