Home » Sponsored » Pi Speakers » Stage, Audiphile(?) or Professional?
Crossover choices [message #50539 is a reply to message #50428] Tue, 16 January 2007 04:41 Go to previous messageGo to previous message
PPoli is currently offline  PPoli
I’m still deciding if buying the JBL 2426 for the upper registry or go with a cheaper one such as Eminence 2002 or better B&C DE500 which seems to have flatter response and, mostly, I can get it locally at a good price.
The main advantage of using the expensive JBL driver could be a lower admitted crossover cut, e.g. at 800 Hz, as suggested in the 2426 datasheet. I haven’t read anything about 800 Hz cut in the forum. At least using the search function: I’m going back reading the topics but it is a time consuming activity, even if really interesting.
800 Hz seems to be a better cut for the couple JBL 2226-2426, but not allowed for any of the other driver mentioned.
I also found a schema for it in the documentation you gently sent me, Wayne.
Can I deduct this is an available option?
And in case, what would be sonically better for you, 1,6Khz or 0,8Khz?
A great advantage, in my opinion, would be that the 2226 has a lack in the off-axis response over 500 Hz which became “important” (-15db) at 1600Hz.
Off-axis response is not so critical in my listening environment, but I prefer to do things in the better (affordable) way.
Previous Topic: 7 Pi plans
Next Topic: Blow Fuse!
Current Time: Wed Nov 04 17:36:33 CST 2026
