Home » Sponsored » Pi Speakers » Wayne, a little more info on the 3 way?
Re: Wayne, a little more info on the 3 way? [message #50367 is a reply to message #50366] Tue, 05 December 2006 22:43 Go to previous message
Sounds like that might all combine to make a pretty good system. I think I'd go with a very simple system having no crossover on the midrange, or maybe just a coil to rolloff the breakup modes. The woofer will need a coil for the same reason. Both woofer and mid will be operating at a low enough frequency that spacing between them won't be critical. Use a first-order on the tweeter and have it mounted on the same baffle as the mid. That will probably sound very nice. Give it a try and see how it sounds.
As for cabinet size, the PiAligned cabinet is slightly overdamped. Works great in most rooms, especially with boundary reinforcement. A B4 alignment works well outdoors, but can be a little boomy indoors.
Previous Topic: JBL 2218 in mid-horn
Next Topic: Premium 7 Plans
Current Time: Wed Nov 25 04:10:41 CST 2026
